Here we go again…
I know this thread was been debated to death here but I would like to hear your opinion about my experience
I know what Yamaha thinks about this (CT vs LDT) ( Yamaha recomends compression test to check how “healthy” is the motor and the leakdown test “just” to confirm from were the leak is coming)
Just rebulit a F100 power head, the cylinder head has pressure tested and resurfaced professinally, cylinder walls hone, new piston rings, new head gasket and valves lapped and test with gasoline for the leakage, some valves lapped twice until no leaks from valves.
Assembled the power head and did a leak down test and had leakage of +/- 30% ??? on all cylinders!!!
Something seems not to be right and in fact I can hear and feel the air coming from the exhaust/intake ports on some cylinders and in one of the cylinders the leakage is coming from the crankcase (piston rings)
I know piston rings and valves may need the motor to work for a while for coat/seat better but on previous rebuilds I did on F40, F50 and F60 after the same procedure I had 10% max of leakage and now 30% ???
Than made pressure test and pressure test and had 200 psi on cylinders #1, 2, 4 and 180 psi on #3 which is good as Yamaha recomends minimum pressure 135 psi
Than made a leak down test again still have the same leakage as before.
What is going on here?
I’m chasing a ghost here?
On my previous rebuils always had good sealing on the LDT after the rebuild.
