Just bought a boat from an auction and she has a pair of 2002 Yammie 225 hp 4 strokes. First pair of 4 strokes, so I am fairly green with them. Upon inspecting the motors I recorded the following compression numbers:
Stb. motor
Cyl 1. 116lbs
Cyl2. 89 lbs
Cyl 3. 81 lbs
Cyl 4 51 lbs
Cyl 5 48 lbs
Cyl 6 85 lbs
Port Motor
Cyl 1 136
Cyl 2 119
Cyl 3 54
Cyl 4 72
Cyl 5 98
Cyl 6 143
In addition the starboard motors oil level was extremely high, to the point that when I pulled the dipstick is came flowing out of the dipstick hole. It also smelled as if it was mixed with gas. Any thoughts or ideas? I filled the cylinders up with motor oil and I will recheck the compression numbers in the morning.
Stb. motor
Cyl 1. 116lbs
Cyl2. 89 lbs
Cyl 3. 81 lbs
Cyl 4 51 lbs
Cyl 5 48 lbs
Cyl 6 85 lbs
Port Motor
Cyl 1 136
Cyl 2 119
Cyl 3 54
Cyl 4 72
Cyl 5 98
Cyl 6 143
