panasonic no mate i havent drained it yet. I will look at it this weekend.
Oil leak
For the drive shaft seals, the upper one (visible after the wear plate is removed) SHOULD have a very small stainless steel TENSION spring around the sealing edge. They do rot away and if not there definitely needs replacement.
Pressure check should be done with NO OIL in the LU....
