what chemical help to clean piston ring grooves before installing new rings?
engine overhaul
Yamaha does not specify a particular grit size for honing the cylinders. That I can find anyway. 240 grit seems to be most common.
I would not re-ring without honing the cylinders also.
I suspect that you know they make tools to clean piston ring grooves. Here is but one.
http://www.summitracing.com/parts/wmr-w80576
without the correct type hone(rigid) and without the proper measuring tools, honing is worthless.
typically on a two stroke piston to wall clearance is about .0015.
typically a max of .003"
the average human hair is about .003".
a hand held hone on a 3/8ths drill in the backyard simply wont cut it.
DO NOT use a ball type hone.
it will excessively chamfer the ports.
