F115 plugs fouling
  • F115 plugs fouling
    I am having trouble with plugs fouling out when at higher rpm's. When I take off wot motor only last about s couple minutes then startes running bad. Change the plugs and it fine till try wot again. If i stay at lower rpms it will run forever and not foul them. It seems to be fuel fouling them as they are real wet when pulled after motor acts up. Any ideas on what could be problem?
    Just curious, how old is your fuel?....maybe contaminated?....
      fuel
      Low octane fuel will give you the same symptoms
        Fouling
        Fuel is new. Gas doesnt stay ling in tank as i burn about 20-25 gallons a night about 2 to 3 times a week. I use only ethanol free but it is the cheapest grade they got, however it is what i been using with no problem for uears now
          measure peak voltages at the different RPMs to make sure all charge coils are in spec
          Have to make sure they are producing the voltage needed, but I am assuming this motor has them
