My tilt and trim works intermittently. If I Tap the motor with a wrench or hammer it works for a couple of times then sticks again. I understand this is most likely the brushes in the motor aren't always making contact. Can I just replace the brushes as they are about $30 each for the two required? If I pull the tilt and trim motor to work on it, do I have to bleed the system or can I just pull the motor, repair it and replace it? An OEM tilt and trim motor costs over $650, and after market is available for around $220. Same question about bleeding or complications I haven't thought of. If its just a matter of pulling the motor and putting a new one in its place, I'll try to do it myself. If it requires a lot of skill and specialized equipment I'll take it to a certified Yamaha Mechanic. The tilt and trim relay was replaced last year and since just tapping the motor lightly corrects the problem for a couple of cycles it must be the brushes. Any comment, advice or help is greatly appreciated. My next step will be based on replies.
Than you in Advance
FLCoyote
Than you in Advance
FLCoyote
