Right after my mechanic changed the computer on my Yamaha 2-stroke 50Ho I started having fuel stravation issues.- He says no connection.
This is what I have done.
1. changed siohon bulp - with Yahaha OEM part.
2. checked the fuel pick-up- to see if check was stuck- no ball it was removed.
3. checked to see if pick-up was free- bleww into and heard bubbles.
4. drained tank to see if there was something floating around and clogging pick-up did not see anything but view was limited.
5, The Boat Mfg had vent line right next to fuel fill line- in fact they shared same space in Fuel Cap. Moved the vent line to the side by itself- installing a circular vent kit. did not change the vent line.
6. The motor starts only have squezzing the prime bulb for a few minutes. starts- I use Neutral and warm motor up at around 1500-2000RPm for five minutes if I return to neutral motor stalls out- To restart have to reprime.
Is the Bulb gone bad again? Do I have a Fuel bulb issue? How can I checK?
Sorry fo long post but wanted to give details.
