Took it into the shop with a rough idle & smoking,miss/sputter feel on accel til around 1200 rpm's,would not go over 4k rpm's at WOT. The shop replaced LP pump diaphrams, cleaned injectors,O2 sensor,regulator screen & VST filter,adjusted TPS from .6 to .5 volts, replaced water seperator filter & checked pick up tube in tank. The fuel lines were replaced last year with primer bulb, new spark plugs & boots,water pump & t stats & pop off valve. The compression tested good. I ran the boat last weekend & the engine idled smooth with very little smoke, on accel it was also smooth & took off good,got to 5k rpm's & could feel it bogging down at full throttle & full trim, what I did notice was everytime I hit the trim up switch, the bogging would go away until I let off the switch. The shop thinks it could be the main relay but is not for sure. Any thoughts on this? Thanks in advance. The engine is a 98 250 ox66 s250txrw.
98 250 ox66
I do not understand how drawing current with the T&T motor would help get more fuel pressure to rail if that is what is happening.
Should be easy to monitor fuel pressures and maybe voltage and current to fuel pump while problem shows up to see if that is what is happening
I have read about the T&T current draw dropping voltage to ECU and causing missing before but not correcting it
