difference due to throttle open/closed is "night and day"
now, caveat: only tested "cold" (if you non-Floridians accept 80F as "cold")
and with a cobbled-together tester (Irma ruined my tester - waiting on a replacement)
so the max values, with throttle wide open, I was getting were only slightly over 100 psi
but with throttle closed, max reading was NMT 40 psi
I'll give it another try next week with a "real" tester, and having run the engine so its "hot"
