150TXRY
its my father n' law's boat. he has owned it since new.
recently it started turning the high temp buzzer on after about a 300yd wot run. pull the thermostats out and it does not go off again. he changed both t-stats and one buzzer, no dice.
yesterday we took a 55 gal bucket with the side cut out and allowed the engine to idle with the t-stats out, with 2 bottles of CLR, then flushed with clean water and then with salt-away. then ran the piss out of it. put the t-stats back in and the same ol buzzer came on. unplugged each buzzer one at a time, each set the alarm off independently. unplug them both and ran it about the same distance and no buzzer (checking for some other short circuit/malfunction).
i wanted to see if any one else has had this problem. the shop he brings the engine to said its likely scale buildup in the head/block. wants to remove the heads and clean it out, but if its in the block then its a much $$.
next step was going to be to flush it with muratic acid and change the wp afterwards.
is it possible its something other than buildup?
