1989 115 hp Yamaha has a problem with not cranking. Will spin over but will not crank, no fire on plugs. Only happens on water. I Have experienced the problem on last 5 times out. By the time I get it to shop it cranks and runs fine. Have had it checked out by 4 mechanics with no problem cranking in their shop. Cranked off trailer today, ran 1 mile, fished 20 minutes and would not crank. This is a repeat of last 5 trips. Loaded on trailer, drove 20 miles home and it cranks fine. Need help on this. Something is changing value. Would a kill switch, or ignition switch be the problem. have checked most connections.
Condition resets between water and shop.
jack glenn
jack glenn
