Hi there. Can you help. I have a one year old Yamaha High Thrust 60hp four stroke motor. all fine till yesterday!
After a ten mile trip at 3/4 throttle, pulling up at a dock the warning buzzer came on when I put the motor into neutral.
In forward or reverse no alarm.
In neutral, motor running, either at idle or revved a little, or off but with the ignition left, or turned on, the buzzer was sounding.
No other warnings from the instruments.
Oil level, ok.
Cooling water, amount and temp, as usual.
After about three hours, with the engine pretty cool again, just the same.
Came home. Everything fine and normal.
On the dock tried it again.....Into neutral and the buzzer came on again.
This morning it's not doing it at all.
Checked the buzzer which is working fine.
Any help would be gratefully received. This is our lifeline as we live in a remote place. Thanks.
Paul
Oil level, ok.
Paul
