Wondering if anyone knows if you can remove the tilt/trim unit from the transom engine brackets with out removing the entire mount from the boat. I removed all the bolts and the pivot pin and can get the unit to move freely, but can't get the unit out. Can you only take it out from the back of the mount? or can you remove the electric motor or resevior to get it out. thanks in advance.
'87 115 tilt/trim
You can take the right side transom bracket loose from boat and power trim unit, loosen the nut on tilt tube and slide transom bracket out enough to get power trim unit out between brackets.
If you cant get the tilt tube nut off then you will have to pull motor off of boat and the trim unit will come out from back of bracket.
