Water exiting Idle Port
  • Water exiting Idle Port
    1000hr on my 225 yamies and port engine has waster coming out of the Idle port on the back of the engine.
    I this caused by the PCV faulty or another issue altogether like Corrosion on ex stack?
    Inspected today and found carbon/soot on the walls with a few spots silver/white on the wall (looks corroded).
    when inspecting the ex stack you must use a bore scope.
    a flashlight simply wont work.
    what your looking for is gaskets that are protruding past the mating surfaces.
    I just reassembled two midsections yesterday.
    both failed and both in different areas.
      I will see if anyone has one in town. these are hard to come by in PNG.
      I have lots of time know to sort this out, this same leg just did its gear box, another thread (back play - back lashing).
      Cheers
