200 HPDI problems
  • 200 HPDI problems
    Good day from South Africa,
    We currently have a 200HPDI outboard in our workshop with a issue that we think is the ECU.
    Motor is not running properly and when we put the diagnostics it we cannot get cylinders 4 and 6 to fire, we changed the plugs out and swapped the coils and still no spark just dead!
    We presumed that it must be the ECU , but we had to be certain as it is a pricy item we thought we would try a used one first.
    We managed to locate another but from a differnt year model, we fitted it to the engine and connected it to the diagnostics and hey presto we have spark on all the cylinders but the diagnostics shows a fault on injector 4.
    swapped injectors and still will not open injector 4.
    Would you guys say that this points to a ECU problem and the second hand ECU is not compatible with the engine?
    If it is not compatible , would we be able to take all the electrics from the blown powerhead and put it on the problematic one?
    Your guys response would be great!
      By the way the engine is a Z200 PETO and the ECU that came off there is as follows
      60F - 22
      F8T60087
      5305
        anyone else care to throw in there opinions?
          if the yds is showing faulty injector then you should replace it ,not swap it with another one ,remember its a chip that dosent understand human interpretation of changing ,when it shows faulty replace it then it will work
