1993 200hp instrument cluster
  • 1993 200hp instrument cluster
    Hi Folks,
    I recently purchased a 21' Bayboat with a 200TXRR 200Hp 2 stroke. I had the engine serviced by a licensed dealer and they said the engine is fine. The instrument panel on the other hand is 98% inop. The oil and temp alarms work but the readouts are shot. Since its a 1993, there are no factory parts options for me. Are there any alternatives such as newer displays available that will function. I don't want to go analog and lose the alarm features. Any suggestions are appreciated.
    Can use 94-2004 Tach rig kit and adapter harness,
    6R3-ADPKT-93-94 93 Engine to 94 gauge adapters
    6YR-W0035-E1-00 Multifunction Tach rig kit, includes wire harness
      ***! That's great. Thanks Mr. Mod.
      Is this a simple plug in adaptor that any average shade-tree mechanic like myself can pull-off or does it involve a much more complicated process to accomplish?
        It's easy, just plugs togather. Set tach for 2 stroke engine, 3 wire trim sender and 12 pole alternator.
