Re:2006 F90TLR yama.
My T/T doesn't give any indication at the CC.
I have the metal finger that the TT sensor arm rides on, it's not the old style plastic finger.
I unplug the long sensor wire at the connector on the side of the motor, this connector is on the opposite end of the sensor arm. I disconnect the 2 screws that hold the sensor in the front of the motor. I put a ohmmeter across 2 connector wires and moved the arm on the sensor up/down. The resistance went from about 50 to 200 ohms, this appears to be normal.
I reinstalled the sensor along with the stationary finger arm and tilted the motor to the down position and monitored the resistance. As the motor started up the resistance changed accordingly. At the transition point from trim to tilt the resistance indicated infinite resistance.
Does this mean the sensor is bad or is this normal operation? It seems like the resistance change should be proportional through the complete T/T range.
