Not sure what that will prove, the engine doesn't know whether you mixed oil in the fuel or not.
1994 Yamaha 115HP 2 Stroke Alarm at high rpms
Originally posted by zenoahphobic View Post
And of course you might be able to check if oil deficiency is the problem by adding 50 to 1 oil to your tank ( mix a small amount if you can empty your tank somewhat), then run to see if alarm doesn't activate.Jason
Originally posted by Jason2tpa View Post
Not completely following you here ^^^. Remember he doesn't have gauges. He also stated borh reserve and main oil tanks are sufficiently full. So if determined the alarm he's experiencing is the low level oil alarm, this would then point to a bad oil level sensor in reserve or main tank.
Engine seizure was mentioned by Panasonic. So I thought it is possible that the alarm is still an overheat alarm if it is caused by insufficient oil getting into the engine. Obviously there is some oil getting in as no oil will seize the engine in a very short time. Thinking three steps ahead to possibly avert damage, it may be a less technical way of diagnosing a problem/ eliminating oil as the problem (more to oil than an alarm and the oil tanks being full) that someone might be more comfortable doing and understanding.
How old EXACTLY is the water pump and did you replace it with an entire kit or just impeller?
Did the WP impeller housing show ANY signs of heat damage?
Lastly, you mentioned fresh water use only. Has that been it's entire life or how long?
I ask in that your issues mimic salt water crud build up in the head/cylinder. -A new water pump (even flowing great), won't fix a clogged cooling system/block/head.
As noted earlier, at high RPM's, there's not enough water flow for the amount of heat the engine is making (with a clogged cooling system).Last edited by TownsendsFJR1300; 01-15-2018, 08:15 AM.Scott
I pulled boat back out of lake and checked to make certain both oil reservoirs, engine and remote were full and they were. I checked all connections to assure nothing loose. I then hooked up the ear muffs, started the water full force and cranked up engine. For some reason the water coming out of the pee hole was not as strong as in the water even though I had the hose running full force and was hooked up correctly over the grates. In neutral the alarm went off fairly soon. I turned off engine and noticed the heads were very hot. We replaced the water pump about a year ago and only use in freshwater. Now I wonder if my issue is overheating. Why would this overheat out of the water with the muffs hooked up and not in the water at idle? Next step a new impeller?
Originally posted by TownsendsFJR1300 View PostHow old EXACTLY is the water pump and did you replace it with an entire kit or just impeller?
I think several on here would tell you even with flushing every time after use in salt water, crud will still build up. Have you checked your thermostat, don't remember if you mentioned that. I think before pulling apart things I would try flushing with one of the mixtures talked about here and see if it takes care of your issue, but that is just me.Dennis
Plus one ^^^. Pull the thermostat, maybe a lower anode, pressure relief valve and check for salt build up...
That should give you an idea of what the innerds look like.
The WP being a year old is about due (by the book) for replacement.
I'd do a WP KIT (a little more $ but worth it)-basic maintenance before tearing down anything major.
IME, with the PO using in salt water, every time you run, get the engine hot and turn off (say to fish), water runs out of the engine and salt
cooks/attaches inside the engine.
I boat in brackish/salt water and flush (extensively). Still found a fair amount of salt in the thermostat/anodes, etc after approx. 10 years of use..Scott
Originally posted by ezzrider View PostI pulled boat back out of lake and checked to make certain both oil reservoirs, engine and remote were full and they were. I checked all connections to assure nothing loose. I then hooked up the ear muffs, started the water full force and cranked up engine. For some reason the water coming out of the pee hole was not as strong as in the water even though I had the hose running full force and was hooked up correctly over the grates. In neutral the alarm went off fairly soon. I turned off engine and noticed the heads were very hot. We replaced the water pump about a year ago and only use in freshwater. Now I wonder if my issue is overheating. Why would this overheat out of the water with the muffs hooked up and not in the water at idle? Next step a new impeller?
Not discounting that your water pump is weakening, in answer to your question, often earmuffs flushing produces a smaller stream and hence if weak enough after some time sets the overheat alarm off, despite ample hose pressure. These pumps work best fully immersed in water.Last edited by ezzrider; 01-16-2018, 08:41 AM.
Originally posted by rodbolt17 View Posteither it is overtemping OR consuming oil faster than it can transfer.
when was the last time the remote oil tank filter got serviced?
Originally posted by Captn Dave View PostI'd start with the thermostats.Last edited by ezzrider; 01-16-2018, 12:58 PM.
Â
