Originally posted by boscoe99
View Post
If the main gear is folded back underneath her, she is done. Once you rip the gear off and the structure around it that is pretty much it...road off. But it doesn't look like there was much way left on her when he hit the dirt, else they would have been in the water and the fuse broke up.
Commercial aircraft are much more fragile then most think. I think they will do a lot more damage hauling it out of there. You can't just hook on and drag it back up the hill. The main gear is the strongest point to hook on to and that is either buried in deep or broke off underneath her. Either way it's going to be very difficult to move it now.
FDR will tell the tale.
All is well, nobody got killed. Airplanes can be replaced. Expensive mistake.
