Where is the oil drain plug located on a 2012 115 hp yamaha 4 stroke? Or do you have to pump the oil out of the oil fill to remove?
2012 115 hp oil drain plug
Oil drain plug
Originally posted by 99yam40 View Postsome prefer to suck it out to keep from cross-threading and/or stripping the threads of the drain screw.
One less thing to worry about
Yamahaoutboards.com shows only two owner's manuals for 2006 and later F115's.
Page 67 of this manual
http://www.yamaha-motor.com/assets/s...07-13_1370.pdf
Page 61 of this manual
http://www.yamaha-motor.com/assets/s...06-75_1369.pdf
I would agree with the others however. In less time than you can remove the drain plug you can suck the oil out of the oil pan. With no risk of cross threading the plug or of stripping the oil pan threads.
A vacuum extraction device with a storage tank is typically used. Or, they also make electric pump driven extractors. Just depends on how much money you want to spend.
https://www.google.com/search?q=oil+...s&ie=&oe=&rlz=
I got a ten dollar flexible vane pump from Home Depot that goes onto the end of my drill motor. It will pump all of the oil out in record time. Just pump it into a bucket.
Originally posted by keylime1 View PostAlmost time to change my oil, so this of high interest to me.
What kind of pump is suggested? Or do y'all mean just suck the oil out thru a soda-straw?
Originally posted by ausnoelm View PostWhy all the paranoid people about changing the oil by removing the sump plug? it is no harder to strip or cross thread it than any other bolt, sump plugs get removed all the time.
I have seen engines with damage from improper installation of a drain plug. I have never heard of an engine being damaged from using a vacuum extraction device.
In the end each is free to choose. Some choose not to change the oil at all.
it happens.
occasionally the AL threads gall to the steel plug and strip on removal.
some get overtightened and strip.
some get cross threaded.
it happens enough that I have some specially modified heli-coils, a modified drill bit and a modified heli-coil tap just for that.
for 100 bucks I can rethread (heli-coil) that bogus thread.
