trim tilt
  • trim tilt
    2003 yamaha 90hp, tilt works in up mode but won't go down. I can hear the relay clicking and after several tries the tilt will go down. which part do I need?
    if you can hear the relay operate but it is not making the proper connection to run the motor then I would be looking at the T&T relay.
    seems like the switches are working if they cause relay to operate
