engine overheats
  • engine overheats
    I have a 2005 Yamaha 200hp HPDI that overheats after about 2 minutes of takeoff. The pee hole water stream is strong. This happened all at once. Thanks, Sonny.
    does it over heat while you are sitting at idle,, if it is only a high speed overheat, check the pressure control valve for being stuck closed,, aka poppit valve..
      water pump , thermostats, and PCV are the usual problems and are simple to replace
        overheating
        No, the engine doesn't overheat at idle and thanks., I will check the poppit valve.
          overheating
          Thanks, I will check out all three fixes.
