I have a 2005 Yamaha 200hp HPDI that overheats after about 2 minutes of takeoff. The pee hole water stream is strong. This happened all at once. Thanks, Sonny.
engine overheats
overheating
Originally posted by Sequoiha View Postdoes it over heat while you are sitting at idle,, if it is only a high speed overheat, check the pressure control valve for being stuck closed,, aka poppit valve..
