2006 90 4 stroke overcharging
  • 2006 90 4 stroke overcharging
    Hi All,
    My 2006 Yamaha 90 4 stroke seems to be overcharging. My volt meter reads up to 17volts. Is it the regulator/rectifier? My battery terminals are tight. Any recommendations are welcome.
    Thanks in advance
    Kajikikai
    Its ur voltage regulator.
      I changed out the regulator / rectifier (about $150 in Hawaii) and problem solved. After searching the forum, I also changed out the wing nuts on the battery to locknuts and lock washers since loosening of the wing nuts while running may have caused the regulator to go bad.
      Thanks again and hope this thread helps someone else out!
      Kajikikai
