Yamaha F250B SWS SDS Prop question
  • Yamaha F250B SWS SDS Prop question
    I just ordered a prop 6CE-45974-00-00 for my 2010 F250B. I guess this come with an damper rubber complete?
    Yes it will come with the correct hub in the prop, but you will still need to get the SDS outer hardware,, the inner thrust washer is the same,
      I ordered the spacer 6CE-45997-00-00, guess this will fit. Just to be sure, anyone can confirm this is the right one?
