YAMAHA 3HP "MALTA" Low Compression ?
  • YAMAHA 3HP "MALTA" Low Compression ?
    I checked my YAMAHA 6L5S017311 MALTA for compressioin. I get 4,5 Kg/cm2 warm engine, 4,8 Kg/cm2 cold engine. The unit is quite old, I don't extactly know it's life history.
    Putting some engine oil inside the cylinder the compression reading (cold) rises to 9 Kg/cm2.
    Which should be the correct reading ? Should I consider replacing the piston rings ?
    Many thanks in advance
    I don't use the metric system, none of my gauges do either.
    using oil to check rings is a waste of oil in a two stroke.
    works,kinda on a 4 stroke cause they have valves.
    do a leakdown test if you suspect ring leakage.
      Thanks for the reply !
      well 4,5Kg/cm2 is about 63PSI, and 9Kg/cm2 is about 125 PSI
      I did the measurement as the manual cracking is very light, I don't feel the resistance pulling the rope I would expect.
      What do you mean for leakdown test ?
