I want to thank those you have responded to my threads. Your help is invaluable.
Unfortunatly, my ECM burnt up. And because of the great advice I've received on this forum. I've learned that the ISC can be the culprit.
I've researched and found that a new ISC can cost approx. $375.00. I haven't had much luck searching ebay, amazon and etc.. Is there other brands that this part will switch out with? i.e. merc, johnson and etc.. If that's not the case, is there a reliable used part seller that I could purchase the part from?
The part number is 68V1312A0000, 115, 4S, 2006.
Respectfully, Robert
