My good running and reliable C90 Yamaha outboard temp alarm goes off sometimes when I run it over 4000 rpms for sustained periods. I have replaced t-stat, pop off valve, water pump and temp sensor and it still does it!!!!!! When it happens I touch motor with cover off its warm but not hot to touch anywhere. It usually stop sounding alarm after a minute or two. Some times I shut it off other times just let it idle till goes off. I know its the temp alarm since my motor is premix. I know its the temp sensor because when I unplug the alarm wire it goes off. As long as I am 3900 rpms I fine 99 % of the time.
What is the problem here?
