Originally posted by Enduroman
View Post
Now, when re-assembling, everything MUST be in neutral. You should be able to spin both shafts (main and the prop shaft) with neither acting on each other nor clicking (borderline engaugement) IF its IN NEUTRAL.
Should you have bumped the shifter, with something soft (or with a thin piece of aluminum) grab the shifter on the LU spline (I'd use a small vise grip with the above mentioned soft aluminum), gently, (don't tear up the splines) and shift it forward and back while having someone turn the main drive shaft. You should feel and see (the prop shaft) go into full engaugement in forward and reverse as you shift.
You want it in-between(neutral), not engauging, no clicking (if it clicks, its partially in forward or reverse).
