Hello,
Brand new to this forum, as I've just inherited a ski boat with a '92 ProV 200 on it. Probably has about 100 hours on it, though it sat unused for several years outside. No luck getting advice on other forums, so I'm hoping for some advice here.
Before starting engine, I drained fuel and injection oil and leg oil and replaced it all with new. I cleaned out the fuel filter too. I also fogged cylinders before turning it over for the first time, and replaced plugs. Runs very well although I do get an overheat warning buzzer if I idle along in forward gear for more than a few minutes. I've since learned that I should have replaced impeller before starting, which I plan to do next. Question - Should i order the impeller kit? How about the housing? should I also do the thermostat at the same time?
Anything else a guy should do to keep this engine in great shape? THANK YOU in advance!
Dan
Dan
