Hpdi 300 timming advance
    did you find some #s or did you have to count the revs?
    Might help someone else down the line
      I marked the flywheel and the prop, and counted the revolution, also the 300 has a water relief tube in it, and the 250 does not.
        Actually, that is a cooling tube. It directs water to the hub of the propeller to help keep it cool.
        • #19
          I was having a tough time trying to figure out what the purpose of it was, I had never seen one before, any idea why only the 300 has it?
          • #20
            the larger F motors have the tube as well.
            its for prop hub cooling.
            backyardigans strike again.
            parts that physically fit yet wont work correctly.
            bad thing is there are a lot of "professional" backyardigans.
            • #21
              3 months I have been trying to figure this out with the low rpm's, it never even crossed my mind that I could have two different gear ratio drives.
