My 2012 F25 hit a rock, which wrecked the prop and bent the prop shaft. I installed a new prop shaft in the lower unit, and a new prop. Now it works fine in reverse, but when I put a load on it in forward gear, it frequently clunks/jumps like a gear is slipping. All the gears appeared to be good when I had it apart. I tried adjusting the shift rod quite a bit, and it didn't make any difference. Any ideas? Thanks in advance for your help.
Best Regards,
Jim
Best Regards,
Jim
