Impeller
  • Impeller
    When installing impeller on a 150txrd counter rotating motor what is the correct way?
    Same direction as old one
      When reinstalling the cup over the impeller, rotate the drive shaft clockwise when viewed from above. It will turn the vanes in the correct orientation.
      It helps to have the impeller lubed with grease, soap, etc to help the cup go down onto the impeller.
        I believe there are some small hash marks on one end of the impeller that indicate top and bottom....don't recall right now which end is down and which is up...
