2003 hpdi 175 no fire on #6 coil
  • 2003 hpdi 175 no fire on #6 coil
    had a problem with fire on only 1 4 and 5 cylinders replaced crank sensor and started firing on all cylinders except cylinder # 6 switched coils from one that was firing with # 6 still didn't make any difference cleaned all grounds and checked all computer connections still not firing on # 6 cylinder
    what method are you using to test spark?
    CPS has nothing to do with spark production on HPDI.
      using an inline spark checker that has a light that flashes also used a clip on one that has an adjustable gap
        you can test the ign coil primary voltage.
        its a 12V transistor switched system.
        at key on you should see 12V from red to ground.
        then slip a paper clip nto the connector black wire.
        use a jumper lead and rapidly strike to ground.
        you should see spark.
        if so test the ground path for continuity to the ecu.
        if you lose a pulser coil you lose spark on that cylinder and fuel is fixed by signals from the CPS and TPS.
        timing will be fixed at 7*BTDC and idle speed increases and top speed cannot be reached.
        the transistors in the ECU act as a set of points, just like grannys old chebby.
          thanks for the information checked for voltage on connector to # 6 coil it only had 3.7 volts on hot wire with key on checked others and they had battery voltage what else should I check
            find the poor connection on the power supply on #6.
            see how simple this is?
            hint, don't go towards the ECU.
            that is not the issue.
            ign coil voltage,like the fuel pump, comes off the main relay and goes to a gang junction connector.
              thanks rodbolt u the man checked for bad connection on fuse holder but had a broken wire in the harness took a while to find but thanks for the input
