I have a Yamaha 150TXR on my Champion 22' Bay. I purchased Yamaha Pro-Series II replacement gauges for the tach, fuel, water pressure and speedometer.
My problem is that on the stock Champion gauges for the tach and the fuel, they utilize molded plugs and the new gauges do not.
On the tach, my current 4-wire plug has a purple, blue, black and gray wire making up the plug whereas the new tach has five wires. The first group of wires is a yellow, black, and green and the second group has a black and a blue wire.
Similarly, the fuel gauge has two molded plugs with four wires each and the new fuel gauge has just 5 wires total.
These gauges are all analogue and are replacing analogue.
Does anyone have a wiring diagram so that I can cut the plugs off of the boat harness and hook up the new gauges correctly?
![Confused](https://www.yamahaoutboardparts.com/core/images/smilies/confused.png)
