cd unit flaw
  • cd unit flaw
    CDI assy (6h5-85540-02) when i removed the unit
    i found the bottom back side covered the a course
    white material(looks like big chuncks of groundup white plastic ? ) it is embedded and covered with the sealing material at the factory from what i can tell. How do i get yamaha corp to examine it for flaws and replace it art
    That is normal, Not sure why but Yamaha does that on a lot of the CDI and ECU's.
      I think what you're looking at is called "heat sink compound" It's used to help remove the heat generated in the electronics to the outer world. ie: to what it's mounted to. The 2 sides aren't perfectly machined, so it's used to transfer the heat. After a couple of years, it dries up and when it's taken apart it's hard. Clean it off and replace it with new compound. It can be picked up at electronic stores or Radio Shack.
      Gerald K4NHN`
