2003 YAMAHA f115 bad ECU
  • 2003 YAMAHA f115 bad ECU
    Hi all,
    I am new in this forum could someone help me i need to find a good used ecu for my yamaha f 115 4 stoke , part no: 68V-8591A-14-00, or mercury part no: 880891T14, as i can understand it the same engine block made by yamaha!!??
    Thanks to help me
    Good luck finding a used part.
    Do you know why the ECU failed? Make sure that the ISC is in good working order. If it fails it can take out the ECU. All too many have simply replaced their ECU, without replacing the ISC, only to have a bad ISC take out the replaced ECU.
      typically, a mechanically sticking ISC valve is the reason for the ECU failure.
        got twin yamaha 115 ,when i swap the ECU on the bad engine all goes well, idle is fine !! must be the ECU itself??
          they are just telling you to look for what caused it to go bad so it will not take out another one
            used part dealer
            I've used a place called Marine Resources 941-999-4084. I just purchased a ECU from them, they typically charge 1/2 price of what a new part would cost.
            In my case the post office, lost item. It has taken some time to get the part to me, however, the owner realized the trouble it caused me and decided to purchase a brand new ECU without upcharging me.
            Ask for Derick or Ron.
            v/r Robert
              USE caution when purchasing items from
              Aug. 15 2013. I purchased an ECU for a yamaha 115 4s, 2006. Please, use caution if anyone decides to purchase items from Marine Resources, 920 S River Rd, Englewood, FL 34223-3910. (941) 999-4084. To date, I have not received the ECU. I was given several reasons for why the ECU isn't here, but after several contact attempts, they have failed to give me a tracking number or returned my phone calls, after indicating they would get back to me in twenty minutes.
