Tilt trim relay location?
  • Tilt trim relay location?
    Can anyone please tell me where the tilt trim relay is located on an 06 yamaha 200 hp????!!!!! Pleas help!!!'
    I can't tell you where the trim and tilt relay is located because I don't know what model of motor you are talking about.
    Is this an F200, a VZ200, a Z200 or ?????
      f200. 2006 model
        It is at the front of the motor. Down low. Find the power wires that run from outside the motor (from the PTT pump motor) into the lower cowling. They will take you directly to the PTT relay. At the relay there is one sky blue wire (up, towards the sky) and one grass green wire (down, towards the grass). Also, a red power feed wire and a black ground wire.
        If it works, activate the cowl mounted trim switch and you should be able to hear the relay clicking.
          Thanks boscoe do you have a picture schematic diagram???
            I posted one in my last message. Did you not see it before it was deleted?
            The relay is at the front of the block, down low. It will be behind the intake air silencer of course.
            Follow the wires and they will lead to the relay.
              Found it thanks for your help
