I replaced my gauges- engines are T- 1997 Yamaha 200 SWS carb'd. Both tachs, speedo and fuel management gauge. This is a new boat to me and the previous gauges were so sun bleached you couldn't even see if they were working.
After replacing them, they all seem to be working correctly. However, the fuel management gauge does not give a gph reading. When I turn the key to on I get 0.0 gph, then when I start the engine I get is a dash where the gph readout should be. Same thing on either or both engines. Bear in mind this was all done on the trailer and engine run at idle hooked up the ear muffs.
Is there so little fuel flowing that the sending unit isn't picking it up? Also, when I push the set button it does not switch from port to starboard to both P/S. When I go to sync, I get the proper readout.
Thank you!
Thank you!
