So I recently purchased a boat with a 2004 SX150TXRC 2 stroke OX66 on it. Ran it on muffs before I bought and then hauled it home and did a water pump and T-stats as preventative maintenance before using. After installing lower unit I fired it up and it ran for about 30 seconds just fine before sputtering out.
I quickly found out the HP pump has no juice so after reading some posts on here I am highly suspect of the relay on the stbd side of engine.
Any way to test this? It has a 4 leads coming out of it. There are black and yellow leads going to a waterproof 2 pin connector. The other 2 are individual leads with bullet connectors one being solid red and one red with yellow stripe. I read a previous post from rodbolt that stated any red/ yellow lead should have 12v+ with key on and the red yellow lead coming out of relay does not have 12V+.
Any other test method for this $200 part? From what I have read on here it seems to be a common problem.
