Folks,
I have had all of the standard filter/HP Pump issues with my HPDI but when I took the boat out today and after hitting some rough seas the 150 lost power intermittently. If I shut the motor down she would run normal for a time then start loosing power.
I had just changed one of the batteries and when I first fired her up the gauges took a few seconds to come on and it motor stopped twice at the dock.
Maybe it's wishful thinking but I live 90 minutes from Key Largo and am hoping I created a bad ground and the ECM is cutting out when the ground is knocked a bit loose.
Is this possible? Obviously I need to check the gas and filters too. Just wondering if a loose ground could cause this type of behavior.
