Motor runs fine at low rpm but when above 3,000 it sounds and runs rough.
I have 120 pounds compression in all 3 cylinder and plugs are new and look perfect.. No water in very fresh fuel (emptied large water separating filter in glass jar).
The motor sounds a little loud mechanically at the higher rpm. I am wondering if a main bearing is going out. How can I tell.
