I just installed a Baystar hydraulic steering system in my boat. There is interference between the Baystar cylinder and the transom at the very top end of the tilt range. The motor is a Yam 90 hp 2 stroke. ('02 TLRA). Is there a way to limit the tilt to the point where it starts to cause interference (without having to eyeball the cylinder every time I tilt the motor up)?
Thanks,
Brian
Thanks,
Brian
