Engine is '96 Yam C85.
The tilt motor runs, makes noise as usual. A little high pitched. I went to drop the motor into the water, released the up lock, pushed the button, won't go down. Added fluid, to no avail.
Climbed onto the back of the boat, pushed down on motor. It goes down a little bit, so it isn't stuck at the mount. Just nothing happens. Tilt motor runs both ways, but engine won't move.
Tried the manual release. It is stuck! Boat is kept in water, so there is some marine growth around arrow that indicates screw turn direction. Which way does it turn on the '96?
