Oil is not pumping into the motor tank from the main tank. VX150TLRZ
Here is the weird part. With no oil in the motor tank, if I trim the motor way up the pump will automatically turn on and start filling. It will not operate by emergency switch either unless the motor is tilted way up. The manual states that the emergency switch will not work if the motor is tilted to high but in my case that is the only way it will work.
Also while trouble shooting I noticed that the fuel pump which usually turns on for a few seconds when the key is turned to the on position, will not turn on anymore unless the motor is now tilted way up.
Is there a sensor that is telling the motor it is tilted down when it is really way up and that is why nothing runs right when it is down in running position? The trim/tilt gauge is working fine.
This one really has me confused. Any help would be awesome.
