Gday all,
Hoping someone can help. I have a 96 mod 115hp Yamaha premix 2 stroke.
Engine will cruise all day around 4000rpm with no problems, start to push the engine a bit harder and eventually an alarm will sound on the control box and the engine seems to go into some sort of limp mode the revs die and the engine will idle for 30 seconds or so, Its still pumping a good stream of water and is not not overly hot once the alarm shuts off the engine will be fine unless pushed again into the higher rev range.
So far I have changed the Impeller and the pick up line even though they looked fine, can anyone advise what this might be, any help appreciated.
