I have a 2006 F200. When the motor is completely cool,(start up and running for the 1st 15 minutes or so), it runs beautifully. After about the 1st 15 minutes, it slowly starts to drop rpms. For example, I will be running at 4800 and it will drop to 4400. If I push the power trim button, located on the controls, for that motor, it will temporarily restore the rpms and you can even hear and feel the engine pick up speed. This will go on until finally the motor starts to cough and pop.
If I take the cowling off at this point, within a matter of minutes, with more air flowing over the motor, the problem will disappear entirely and the motor will run fine.
Can anyone give me a direction on what part may be failing to cause this phenomenom? Sensor? Wiring? Fuel?
Thanks.
Thanks.
