New 25 hp 2 stroke question about charging system
  • New 25 hp 2 stroke question about charging system
    I just purchased one of the last new 25 hp 2 strokes in my area( built November 2011) ....I also bought a rectifier and installed it ..motor has 2 green wires from coil under flywheel and 1 yellow/red ..... 1 pink coming out of the CDI box ....NO other loose/open wires
    The Yamaha rectifier I installed has 2 green , 1 black and 1 red with inline fuse
    I joined the 2 green to the 2 green , black to engine ground and red to battery positive
    With engine running at idle output is 6 volts , increase rpm and I have 20 - 25 volts ....way too high !!!!
    Checked output of pink and yellow/green wires ...nothing at all , idle or half throttle
    ANY HELP WOULD BE GREAT OR A WIRING DIAGRAM OF THE GENERATOR CIRCUT , MORE SPECIFIC ..WIRE COLORS
    Chris
    Anybody ??????????????????????????
      A rectifier only converts AC voltage to DC voltage. It does not regulate the voltage.
      Perhaps you now need to add the following:
      2013-MRP-Catalog
        typically on the small engines the battery is the regulator.
        however occasionally we have to add a regulator.
          thanks for the idea's / input
