20A /25A conversion
  • 20A /25A conversion
    own an 20A long and an 25A short...both older engines late 70's
    need it just in reverse 20A short/25A long...
    is it possible to switch the tail-ends??/
    measures are simular..but how about the drive-axes ??
    greetings from holland:
    jan
    Not familiar with those motors. If the drive shaft housing are the same lenght and there are 5 inch spacer that can be removed and swap over to other motor then it work if drive shaft splines and shift shaft are the same.
