yamaha 703 and fast idle
  • yamaha 703 and fast idle
    I reattached my yamaha 703 control box after replacing the motor and converting the control box from pull top push throttle. My first problem was the idle throttle lever didn't engage and all and when I return the throttle to neutral it idles high. Well i removed the control box and realized I had a know in the wrong place and so now the nuetral throttle lever works but it still remains at high idle when returning it to nuetral. When I start it there is no problem but once I put it in gear and return it to nuetral the engine idles high.
    I have isolated it to the control box as before I figured out that I needed to switch knob locations when I convereted from pull to push. The neutral throttle lever would not function BUT I was able to pull it up when the engine was at high idle and it would reset it and it would idle normal. It is hard to explain and will answer any questions I know I am missing something I just can't figure out what. Thanks
